Fitted the clutch, no pictures of inside I'm afraid; I was too busy swearing at it
As I fitted it into place the flat splined washer under the clutch kept moving slightly out of place meaning the clutch wouldn't sit properly. Took me two attempts to sus this out. Once I realised what was happening a small dab of grease to hold it in place and it went on easy.
Piccy of shinyness-
Oops, upside-down!
Next, the top end, but I need to order a genuine headgasket, the one in my dodgy pattern gasket set looks very suspect, like a bit of tin foil.
Mike
P.s. I just looked at the photo- I need to clean up a few of those bolt heads
Just another job on a long list............
