stuck bolts
stuck bolts
Hi all,
this is a constant source of frustration when I'm doing work on the bike...the bolts either shake off when you definitely don't want that to happen, or they are so tight I can't for the life of me get them off.
I've tried anti-corrosive and oil, to no avail. So I was wondering what everyone else's fix for this is??
- Howie
Heat is quite good but obviously not where it will cause damage! I usually end up drilling them out & re-tapping, not a quick process
When you put bolts back in, I would use copper grease for bolts that you will need to remove from time to time & thread lock for those you want to stay put!
Bikes are just a nightmare at times!
Been there done that. I have stopped using the heat approach, because the last time I used it, I ended up with the bolt still as stuck as ever, but managed to burn both my thumbs in the processHowie wrote:Heat is quite good but obviously not where it will cause damage! I usually end up drilling them out & re-tapping, not a quick process![]()
I have also done the drilling before, but as you mentioned, it is anything but a quick fix. I think it took me around two hours/bolt and it was really frustrating.
Sometimes it feels like the bike is trying to p*ss me off...
Working on the ones securing the KIPS motor on that little 'platform' above the engine. I guess I couldn't drill those out even if I wanted to...heat may not be advisable either....
Also was trying to take off the sidestand assembly, and those bolts won't budge either. I'll try tightening them a little more, see if that helps. Thanks for the advice, it is much appreciated!
lucy
lucy
Try soaking them in PB Blaster Penetrating Catalyst. It is an American penetrating fluid. £3.99 on eBay.
KR250 Tandem - Love It
KR1 Project - Sold
XT600Z 3AJ Tenere Overlander
TDR250 - Road & Track
KR1 Project - Sold
That statement could be misconstrued sooooo easily.lt_kr1 wrote:Yup, the impact driver is my best friend...if it helps loosening bolts thats pretty much just an added bonus, it has become a form of therapy for me...
Yes, I know..... Shame on me.
