stuck bolts
Posted: Sat Feb 06, 2010 3:48 pm
by lt_kr1
Hi all,
this is a constant source of frustration when I'm doing work on the bike...the bolts either shake off when you definitely don't want that to happen, or they are so tight I can't for the life of me get them off.
I've tried anti-corrosive and oil, to no avail. So I was wondering what everyone else's fix for this is??
Posted: Sat Feb 06, 2010 4:05 pm
by Howie
Heat is quite good but obviously not where it will cause damage! I usually end up drilling them out & re-tapping, not a quick process :(
When you put bolts back in, I would use copper grease for bolts that you will need to remove from time to time & thread lock for those you want to stay put!
Bikes are just a nightmare at times!
Posted: Sat Feb 06, 2010 4:12 pm
by lt_kr1
Howie wrote:Heat is quite good but obviously not where it will cause damage! I usually end up drilling them out & re-tapping, not a quick process :(
Been there done that. I have stopped using the heat approach, because the last time I used it, I ended up with the bolt still as stuck as ever, but managed to burn both my thumbs in the process :oops:
I have also done the drilling before, but as you mentioned, it is anything but a quick fix. I think it took me around two hours/bolt and it was really frustrating.
Sometimes it feels like the bike is trying to p*ss me off... :(
Posted: Sat Feb 06, 2010 4:33 pm
by Howie
Which bolts are stuck? It_Kr1.
Another tip is to try to tighten them up (don't go mad here :lol: ) then try to undo them, this sometimes works [-o<
Posted: Sat Feb 06, 2010 7:00 pm
by lt_kr1
Working on the ones securing the KIPS motor on that little 'platform' above the engine. I guess I couldn't drill those out even if I wanted to...heat may not be advisable either....
Also was trying to take off the sidestand assembly, and those bolts won't budge either. I'll try tightening them a little more, see if that helps. Thanks for the advice, it is much appreciated!
lucy
Posted: Sun Feb 07, 2010 1:15 am
by Cexley
Try soaking them in PB Blaster Penetrating Catalyst. It is an American penetrating fluid. £3.99 on eBay.
Posted: Sun Feb 14, 2010 10:37 am
by lt_kr1
Just thought I'd let you guys know, I've finally managed to get the bolts off. It wasn't pretty though there was a lot of swearing in the final stages...
Thanks for the help guys, don't know what I'd do without this forum!
lucy
Posted: Mon Feb 15, 2010 10:21 am
by Bikemike
Always worth trying an impact driver, even if it doesn't work smacking it with a hammer makes you feel better :D
Posted: Mon Feb 15, 2010 11:58 am
by lt_kr1
Yup, the impact driver is my best friend...if it helps loosening bolts thats pretty much just an added bonus, it has become a form of therapy for me...
Posted: Mon Feb 15, 2010 12:19 pm
by ScottaKR
lt_kr1 wrote:Yup, the impact driver is my best friend...if it helps loosening bolts thats pretty much just an added bonus, it has become a form of therapy for me...
That statement could be misconstrued sooooo easily. :lol: :mrgreen:
Yes, I know..... Shame on me. [-X
Posted: Mon Feb 15, 2010 12:23 pm
by lt_kr1
:oops: oh dear I guess I should watch what I'm saying on here...
Posted: Mon Feb 15, 2010 12:58 pm
by scooble
I always found the impact driver very satisfying for taking my frustration on those really difficult nuts
Posted: Mon Feb 15, 2010 1:00 pm
by ScottaKR
Sorry, I just couldn't resist.
Perhaps my keyboard needs an alcohol interlock fitted to stop me posting after drinking. :-k
Posted: Mon Feb 15, 2010 2:15 pm
by Howie
:lol: :lol: :lol:
Yep, mine too
