It all started just before winter (if I remember rightly) when I got the kmx out of the shed & tried to start it. The Kmx usually would start 2nd or 3rd kick but the bastard decided it just wasn't going to!
After checking all the normal stuff I then decided to do a compression test, this came in very low at 85psi, so I decided to whip the head & barrel off & thats when it all started to go tits up
The barrel was scored (quite deeply) But the piston & rings were in sound condition
Anyway, so one thing led to another & I decided to give the Kmx a bit of TLC by stripping it completely, starting with the engine, ho ho ho.
First pic, here is my scabby old Kmx (88 model)
[img][img]http://i800.photobucket.com/albums/yy28 ... ie/081.jpg[/img][/img]
It was still running in this pic
Heres a pic of the engine minus its barrel
[img][img]http://i800.photobucket.com/albums/yy28 ... /021-1.jpg[/img][/img]
Over the years I have picked up bits & bobs, like oil seals & gaskets etc off ebay, bloody glad I did but I wasn't expecting this-
[img][img]http://i800.photobucket.com/albums/yy28 ... /024-1.jpg[/img][/img]
As there was no bits of metal in the oil I drained or any bits stuck to crank cases etc, this was put back on
I always thought the gear shift shaft was a little bent &
[img][img]http://i800.photobucket.com/albums/yy28 ... /023-2.jpg[/img][/img]
[img][img]http://i800.photobucket.com/albums/yy28 ... ie/025.jpg[/img][/img]
It was
[img][img]http://i800.photobucket.com/albums/yy28 ... ie/027.jpg[/img][/img]
But lets not go mad eh?
Finally, the KIPS mechanism, here is a pic of the cog, can anyone spot the problem here? Honestly, this is how it came off
[img][img]http://i800.photobucket.com/albums/yy28 ... ie/026.jpg[/img][/img]
It appears that the pin has been glued on(?!) Why glue the pin on here? why not put it back in its hole? Am I missing something? Bloody motorcycles!
