head problem
Posted: Thu Apr 15, 2010 8:20 pm
hi everyone!!!
i have a question i would like to ask you guys
my 1s is leaking water into RH cylinder,i noticed when i looked into the radiator and saw that the water was gone,and besides that,the water goes out from the thank under the seat through that little hose.
also i knew the water was going into RH cylinder because when i took out the spark plug it had water in its electrodes.,
so i think three bond sucks,so i took out the head,cleaned both cylinders top and cleaned head an gasket,then i put them back together and gone to ride.
when i came back home,i waited it to get cold and check the water level,and guess what,it was gone again,where??
into the RH cylinder again
so here is my question
do you think i need to replace the head gasket??
or the head is warped??
please tell me waht you think
