i have a question i would like to ask you guys
my 1s is leaking water into RH cylinder,i noticed when i looked into the radiator and saw that the water was gone,and besides that,the water goes out from the thank under the seat through that little hose.
also i knew the water was going into RH cylinder because when i took out the spark plug it had water in its electrodes.,
so i think three bond sucks,so i took out the head,cleaned both cylinders top and cleaned head an gasket,then i put them back together and gone to ride.
when i came back home,i waited it to get cold and check the water level,and guess what,it was gone again,where??
so here is my question
do you think i need to replace the head gasket??
or the head is warped??
please tell me waht you think
