mj43
Posts: 1329 Joined: Tue Jul 25, 2006 7:44 pm
Post
by mj43 » Sat Apr 24, 2010 7:57 pm
Rather than the usual ZXR400/250 route gone something different
TZ250 forks with Spondon adjustable yokes, though at the mo' yokes are set up to match the Stock KR setup.
TZ forks are slightly shorter than KR forks so I have had a set of extended fork caps made up so ride height is the same as the KR.
Brakes are TZ 4 pot Nissan calipers discs are KR1 which reduces rotating mass and weight significantly.
Will test them in the next week or two and see if this is the answer to my front end woes.
Bikemike
Posts: 1193 Joined: Tue Jul 25, 2006 8:51 pm
Post
by Bikemike » Sat Apr 24, 2010 10:56 pm
Love those yokes.
Mmmm, Spondon
THE FLUTE
Posts: 474 Joined: Fri Jul 28, 2006 1:18 pm
Post
by THE FLUTE » Sun Apr 25, 2010 9:36 am
That look's lovely Mark I like the yolks. Glad to see you give yourself space to work on the bike
Will we see it at Cadwell
Posts: 1549 Joined: Thu Jul 27, 2006 12:47 pm
Post
by scooble » Sun Apr 25, 2010 11:37 am
Umm, very racing bling - love the yokes too
mj43
Post
by mj43 » Fri Apr 30, 2010 3:50 pm
Doh why didn't anybody tell me?
In my excitement I swapped the forks over. So after carefully measuring spacers and getting them made - brill everything spot on
Until I put the mudguard on and it doesn't fit
No prob swap the forks round - now none of the spacers fit
The word muppet springs to mind ......
Post
by scooble » Fri Apr 30, 2010 4:57 pm
I did the same when I fitted my 636 forks
Glad I'm not the only one!
mj43
Post
by mj43 » Fri Apr 30, 2010 5:55 pm
Fixed - 10 minutes to recommission the lathe and a new set of spacers knocked up.
Now one disc is true as can be - the other is wobbly. I am hoping it is just a case of it being lying around for a while and it has just sat oddly on the
bobbins. A bit of use and she will straighten up?
All a bit experimental - I am hoping to get her ready to try out on Monday at Cadwell and if all is well dial her in over 4 races (well more like test rides).
If not it will have to wait until Snett.
