Thanks Gary
Welding
- kwackman12
Welding
Just had one of the barells repaired of my race bike (small crack where it trys to lift off the crankcase) Had it done professionally heated in a oven then welded only problem I have is when it was heated the plastic metal that is used to smooth the edges/ports has fallen off, their two complete pieces would it be ok to "re-stick" them on or should I replace with new & regrind them? Also whats best to use. I have a meeting at Brands at the week end so need to get it done asap.
Thanks Gary
Thanks Gary
KR1 race bike
ZXR 400 Race Bike
Aprilia RS250
ZXR 400 Race Bike
Aprilia RS250
I have heard of using plastic metal in the ports to create a "choke" in the port to increase the inlet velocity and to stop gasses traveling back into the crankcase.
