Jacques
Post
by Jacques »
Hi all. How will i know i must replace my crank seals? Plz and thanx
Enjoy life it 2 short
Post
by Luders »
Your transmission oil level will mysteriously drop with no apparent leaks, is one way to tell.
Jacques
Post
by Jacques »
Luders wrote:Your transmission oil level will mysteriously drop with no apparent leaks, is one way to tell.
Thanx but iam going 2 use the crank i take out of the old motor so i dont know
Post
by Luders »
I see, so you'll be able to inspect the seals and see if they are perished or have deteriorated.
Jacques
Post
by Jacques »
I can take the seal and move it around the shaft with no problem. And the problem it the inners? So any atwise plz
Post
by Luders »
Crank seals are notorious for going soft and leaking. If you can move them around easily, I would replace them whilst you have it all apart now.
You'll be irritated to have to strip it and replace them if they are leaking.
Post
by Charles »
I'm afraid you can't judge them visually and be 100% sure they will do their job, there's always a risk....
Jacques
Post
by Jacques »
So true . Thanx again just hope i get that part in south africa
