Hi folks,
I'm looking for a bit off a knackered fairing top to patch into mine. I'm looking for a section of the right hand (sitting on the bike) top from at least half way down the access panel to its junction with the lower panel.
I'm trying to make the best of the fairing I've got (various minor repairs - pretty well done), but it's got a lot of fibreglass on the bit in question, and a 'welded' in section would be much better.
Tambo
Part 1s Fairing Repairs
- Tambo
- Tambo
Lee (frog32) has got an original fairing in red/gray for sale, might be an option for you?!Tambo wrote:Update -
Never managed to get any bits of fairing. Experimenting with timber formers, sheets of abs plastic, a heat gun, and plastic welding !!
It it works, I'll publish, if not, I might have a street fighter
- Tambo
- Tambo
This looks to be doing the job
I'm having phone / camera problems, so I'll collate all the photos and do a proper explanation asap.
Basically, I've made a timber former of the part I needed, cut abs shapes, and bent them to follow the profile of the former using a heat gun. The sheets are then joined with a combination of proper plastic solvent, and plastic welding.
With a bit of practise, I'm sure most plastics could be made / repaired.
Outer fairing shape, and inner lip for access panel
Bent shapes glued, and plastic welded (through holes)
Fairing with offending fibreglass corner removed
New part glued into position
Lots of little cracks still to be welded before painting, but it's getting there !!
- lurker
bike need to be repair
The bike seems to be awesome but need some more restoration. But as you have mentioned that all tiny works has been done, and if you need to change the body parts be sure isn't it going to ruin the best part of the bike.
