KR250a1 Carb issue
glidercoach
KR250a1 Carb issue
Post by glidercoach »
Wow I'm so happy to ask a question OTHER than that damn intermittent spark issue. She fires up on the first kick hot or cold! I don't remember it ever doing that! New question: My bike wont run right unless I keep the choke on a little. I cleaned the bowls (they were clean as they were) and checked the float levels... There are no vacuum leaks... It sounds like the front cylinder is more affected than the rear. Eventually it stalls at idle if I don't choke it a little. Any input anyone? Thanks! :?
glidercoach
Never mind... I'm an idiot! Don't know how I missed the smaller jet. It was plugged up so I blew it out and it fixed the problem. Runs and idles fine without the choke... I'm so excited, I have my KR back. The new windscreen should arrive in a few days then I'll crate it up and off to Italy it will go! \:D/
