VHM Heads
Camus14
VHM Heads
Post by Camus14 »
Hello everybody
I'm new in this great forum!
I'm from france where it's probably harder than in UK to find parts for that wonderful bike...so, I asked the pro to make ones!
I would like you to know Heikki from VHM is interested by making heads (separates not one piece as the OEM one) if there's enough people interested!
Could you be interested?
Post by alimorg »
Hello and welcome, sounds interesting what would these heads cost?
Al
Yep I would be interested in some with removable combustion chambers.
Oh and welcome
Post by Charles »
Welcome! We've discussed this before ( viewtopic.php?t=1907&start=30 ) :
mj43 wrote:Take care with it. I was told that the cylinder head holds the engine together.
This mod was apparently tried in the early '90s and the crankcases on modified bikes cracked!
When I designed my billet heads, though the heads were individual the design allowed a bridge to be fitted to replicate the bracing a one piece head provides.
What is the performance benefit from having seperate heads?
I do not see this as much of an enhancement and more of a stress on the engineering to be honest.
Can you please explain?
Thanks, Ben
Luders wrote:What is the performance benefit from having seperate heads?
Thanks, Ben
it has some advantages :
* you can switch combustion chambers so the needed power matches the track
* in case off engine failure, you only need a new insert, which is fairly easy/cheap to make.
* same for experimenting engineconfigurations : if you are good with a lath, you can make the inserts yourself, in stead off having to re-weld your cylindre head and re-machining.
* if designed properly, the head even has better colling.
Something just doesn't quite stack up for me, but i would be interested in what you lot decide to do with these.
VHM individual separate heads
...from my discussion with VHM (a while back)
the main grief is new hoses and thermostat housing solution (extra expense)
smaller solvable problems...
the extra sealing o-rings would be required around the KIPS (gasket side runs very close to where the chamber o-ring, and insert sits)
and the fact that even a universal individual head design would require slight deviations for the KIPS cable end mounts (see top photo)
the price was inline with the other products at around £400 mark (KR set)
I think will have to get some 56mm (KTM) inserts and modify the KR head for inserts first
organising people to front up and rely on them is another story
CHARLES' machinist was keen on having a go to make heads as well
a group buy on stainless pipes (bring them below £400 pair again) and Im in
Re: VHM individual separate heads
Post by Charles »
KR-1R wrote: CHARLES' machinist was keen on having a go to make heads as well
I first need to sell off the valves and pullies I still got before I start another project.
