hot and cold
Posted: Fri Mar 25, 2011 5:46 pm
by jarno
Hallo i have a question
when i start my engine the left side stays cold but i think it is running on 2 cillinders.
also the left sparkplug stays wet but it has a good spark
what is the problem.
Jarno
Posted: Fri Mar 25, 2011 5:53 pm
by martin
if not coil[try swapping leads round]
i think your tickover screw on the left needs turning in[raising the throttle
body]
Posted: Fri Mar 25, 2011 6:07 pm
by jarno
I will take a look at the carburetators i have cleaned them so it is possible
thanks
Jarno
Posted: Tue Mar 29, 2011 3:56 pm
by john-b
sounds like a crank seal has gone, see if the gearbox oil smells of petrol is the easiest way to check and it will be harder to start. It maybe using gearbox oil too although the flywheel side runs dry.
Just another avenue to check, i cant see it being carbs as the plug is wet.
Re: hot and cold
Posted: Wed Mar 30, 2011 8:49 pm
by Charles
Hi Jarno,
jarno wrote:but i think it is running on 2 cillinders.
is it running on 2 or not: do both exhausts get warm?
groeten,
Posted: Fri Apr 01, 2011 4:50 pm
by jarno
Hello.
It is sorted out now on of the carbs air screw was closed.
now it is getting warm on both sides.
thanx martin
