Hallo i have a question
when i start my engine the left side stays cold but i think it is running on 2 cillinders.
also the left sparkplug stays wet but it has a good spark
what is the problem.
Jarno
hot and cold
john-b
sounds like a crank seal has gone, see if the gearbox oil smells of petrol is the easiest way to check and it will be harder to start. It maybe using gearbox oil too although the flywheel side runs dry.
Just another avenue to check, i cant see it being carbs as the plug is wet.
I wish i knew something about KR's so i was like knowledgeable about them and everything like what you lot are
Re: hot and cold
Hi Jarno,
groeten,
is it running on 2 or not: do both exhausts get warm?jarno wrote:but i think it is running on 2 cillinders.
groeten,
