Head Bolts
Head Bolts
A technical question for all of you mechanical geniuses out there....
If I wanted to replace the head bolts with a stainless steel replacement =P~ , what grade/specification stainless steel would they need to be made of to match/exceed the specification of the standard high tensile steel bolts?
Bernie :D
Post by SP_BOTT »
As far as I know, no stainless is going to be as 'hard' as high tensile, standard 'over the counter' stainless fittings are A2 and the harderr versions is A4 (stamped on the bolt heads) both these are softer than 8.8 high tensile, (ie your head bolts) and Allen bolts are higher still, at 12.9 hardness.
I'm no expert, just what I'm lead to believe.
Bit boring, but shows a few examples
http://autonopedia.org/crafts_and_techn ... kings.html
Thanks for the info....
Black high tensile it is then!
Post by scooble »
my bike is currently down the machine shop, therefore can anyone tell me what the dimensions are for the standard head bolts so I can find alternate replacements
Hi Scooble,
8x40
Post by scooble »
is that M8 1.25 or M8 1.5?
Tel
Post by Tel »
:?: On the subject of thread sizes/pitches, is there a list of bolt thread pitch sizes anywhere? :?:
Tel
Prilla 650Peg (commuting battleship)
Klx125
KR1S-C3 ss300 (deceased, with resurrestion plans)
standard M8 scooble, so it's 1.25 :wink:
