BUDGET CLASSIC RACE/TRACK BIKE BUILD: 88 KR1 250
blanc
Post by blanc »
Hi All,
I purchased an abused ex track bike that had sat idle for seven years. The bike I am told is a 88 KR1 250.
I have not ridden on the track due to the Irish economy in four years, this will be my first attempt back! =D>
So If you guys have old road spares lying round please help out, paypal waiting for cheap parts.
Day one
Not too bad right.......pfffffffffff ](*,) ](*,) ](*,) ](*,) ](*,)
blanc
Post by blanc »
Day 2:
Strip down begins
Ohh good god where is the powervalve motor?...whats with all the cable ties, cable tie holding the carb on....what have I bought.... ](*,) ](*,)
Leave Shed
Post by Bertie_Mollie »
Welcome :D
I have a cheap front Muddy tastefully painted in blue if you are interested :lol: - £7.50 + post.
If there is anything else you need help with please let me know.
Andrew
GWB KR1s C2 - Now gone :-(
GWB KR1 - YES IT'S DONE!
ZXR400L PROJECT :shock:
AND NO S****Y H****A'S
Usque Ad Mortem Bibendum
blanc
Post by blanc »
Day 3;
Surveying the damage
Image Note: Missing oilpump cover, lockwire.
Clutch cable
Cracked RH Clipon
Powervalve linkage mess....wonder what Ive done leave shed again...
blanc
Post by blanc »
Gather thoughts together...decide to remove engine and continue
Image Engine out
Could you chance using this head?
Image Strange bore, liner coating? Useable?
At least one is useable
I might be able to find some wider cable ties as well :shock: :lol: :lol:
blanc
Post by blanc »
SLIGHT PITTING TO FORKS...BODGED ON CALIPERS OFF A FIREBLADE, EITHER NEW BRACKETS OR STANDARD CALIPERS NEEDED.
RESULT: HOURS OF CLEANING, AND TRIPS TO HIGH POWER DIESEL WASHER :-&
blanc
Post by blanc »
I have a tiny budget but will get there so far my needed parts list include
One piston and Rings, Gudgeon bearing.
Engine Gasket Set
3 x Powervalves, Powervalve pullies and 1 x linkage.
Exhaust Gaskets
Powervalve motor and bracket
RH Clipon
LH Rearset
Front master cylinder
Rear caliper and bracket
RH passenger footrest/exhaust hanger
All parts including the piston will have to be used for now, once up and running I will replace the forks and shocks when racing again. My budget is a wopping 200 :-({|=
All thoughts, comments, tips and help much appreciated.
blanc wrote:I have a tiny budget but will get there so far my needed parts list include
Engine Gasket Set
Exhaust Gaskets
RH Clipon
LH Rearset
Hi Blanc,
I can help with:
Used piston, rings. gudgeon + little end brg
KR1S RH clip on
LH rearset
RH pass footrest / hanger
Rear caliper bracket
KR1 front master cylinder
£50 + post
Andrew
blanc
Post by blanc »
pm sent.
Thanks for the offer on the mudguard, I also have a resprayed blue one
To fail is to not to have tried at all.....Push your boundaries!
Engine Gasket Set
Exhaust Gaskets
RH Clipon
LH Rearset
Hi Blanc,
I can help with:
KR1S RH clip on
LH rearset
£50 + post
Andrew
I am not after any parts,but i want to give you a pat on the back there matey =D> .
Nice to see there are still some right folk about :) .
Oh forgot to say,good luck with it Blanc 8) .
Brave man \:D/ .
Hi Blanc got your work cut out there looks familiar to me when i got mine as are some of the other heaps people have picked up, but never worrie you'll get all the help you need on here, just check out some of the projects and see how they have been turned into great kr1/s, no matter how dirty things get they'll always clean up, and welcome to the forum cheers wayne.
who the F*uck is crazy enough to run that setup :shock: ](*,) #-o
blanc wrote:SLIGHT PITTING TO FORKS...BODGED ON CALIPERS OFF A FIREBLADE, EITHER NEW BRACKETS OR STANDARD CALIPERS NEEDED.
If I were you, I'd change the outer tubes off the forks to KR-1S. The calipers are a straight fit (you just need spacers for the bolts, or go one up on the thread in the calipers). Outer tubes should be cheap to find, lot's off them survive a crash while the inners don't, or forks are putted aside because off pitting, and swapped for better ones. this way, you'll have much much better brakes than putting the original calipers back on
outer tubes are interchangeable between KR1 and KR1s :wink: :idea:
blanc
Post by blanc »
Thanks for the comments and advice, keep them coming!
sounds like a great idea to me. will take a look..By using the kr1s outer tubes will the blade calipers just bolt up?
