KR1 Main Swingarm Bearing Replacement
Hi Guys,
Just about ready to fit these. I assumed it didn't matter which way round they went in but there is a slight flange on one side with the part number on.
These are genuine items so there is no question about them being incorrect.
Does the part number face outwards i.e. with the larger flange to press on?
Also - was going to use a long threaded stud and washers / sockets to pull them in after the bearing have been in the freezer.
Any other recommendations?
Andrew
Andrew
GWB KR1s C2 - Now gone
GWB KR1 - YES IT'S DONE!
ZXR400L PROJECT
AND NO S****Y H****A'S
Usque Ad Mortem Bibendum
ZXR400L PROJECT
- Howie
- tescr500
http://www.kawasakimotorcyclespares.co. ... 6695&uid=0SP_BOTT wrote:Hi, can I ask how much they were and where you got them from please?? it's the only part/s thats stopping me from starting my rebuild (after 2 years)
but they are available from a few places
- tescr500
Hi tescr500 are you sure this is the main arm bearings? (and not the smaller dogbone bearings) I've not placed the order yet, but thought they were these ones ???? Not sure as they don't use the kawasaki part numbers.tescr500 wrote:http://www.kawasakimotorcyclespares.co. ... 6695&uid=0
http://www.kawasakimotorcyclespares.co. ... 6666&uid=0
Great site BTW, not seen this one before, they even have original fairings that they appear to have on stock?
- tescr500
Kawasaki
OEM#: 92046-1140
Thats the part number above, but im sure if you take it to a quality bearing supplier they will match it, might even be the same maufacturer, mine were from a bearing supplier.
OEM#: 92046-1140
- tescr500
- Tambo
I bought a bearing remover from evil bay - there is a piece like a wine cork with a spit in it and a bar with an end like a flat blade screwdriver - you put the cork shape in from the front then push the bar in from the back. The flat blade spreads cork shape - you hammer it in until its gripping good and tight with the cork pressing on the bench - then give it a good welt (or 10) from the back and it will come out - cost about £19 and made in China. I changed all the bearings in n RGV swinger and there is no way they would have come out without the right tool.
Salty
Salty
- Tambo
