do the barrels need boring/replating for 4dp pistons as there were some on ebay recently stating they were intended for a kr1 s but had to big a bore? always thought machinig head to suit deck height/profile was only required. i understand that 26j are nla so will resort to 4dp if more appropriate? are the 4dp easiest to come by/the most straightforward mod? heads look trick btw, and there just the modded stock ones! cant wait to see the one off items your having done fitted to the bike! cheers matt.
To run 4DP or 4AK or 3TC pistons the barrels need to be shortened by 2mm (need to check that figure so don't go cutting just yet).
Then I advise strengthening the barrel - rather strengthen it first then shorten it - takes out the distortion put in by the welding.
If you don't then the barrel will fail - will show piccies of what I have done and how they crack
If you run 3TC or 4AK then the head just needs re-profiling.
If you run 4DP - ideally it needs welding but you can just skim and re-profile keeping a hemi-head. There is a spreadsheet on my website (which I know is falling apart) which allows you calculate volumes etc.
The head in the piccy wasn't a success - compression to high and lost overrev. I have a reworked one to test but need to get some barrels sorted. Mean time I will be racing on a set of old 26J pistons
there is some pistons on ebay atm (59w) do these pistons fit,are they same bore/stroke as 26j etc? desperate for some so will give padgetts/dennis trollope a bell,unless you know of some were cheaper? if there no good then will get a set of what you already mentioned once you post specs. info was helpful cheers matt
mark, ive sourced some 4dp pistons and have a good supply. just about to get the bracing/machining done, could you post me a piccy of were to weld and how much to remove? i think you sent the specs so ill have a look to check, any other tips/things to look out for would be greatly appreciated, cheers matt. p.s, good luck at mallory!
mark, could you give a ballpark figure on the price of oneoff heads to be made with inserts ala rs h***a etc and also bigger cooling capacity like a ''coolhead'' type design? i understand you have put your billet heads on hold for now but im intrestred in the idea of better cooling potential aswell as o ring and been able to alter the combustion spec, not to mention det rings. another good thing would be getting rid of that horrid step near the gasket between the head/barrel. i know the rgv boys have modifyed std heads with great sucsess but seems the powervalves location makes the kr heads awkward to do the same mod.
I have two sets of heads made so could probably let you have a set. If you want to try finishing the development. I can't see myself getting round to doing it as I have another much bigger project I am starting after Bonneville
If you are up at Cadwell 28/29 I will bring the billet heads up.
i will be at cadwell to see the strokers in action in the form of f250, i would happily try and finish developing the heads mark, could you pm me? i am looking forward to finding out what your up to, sounds intresting if the heads are been cast aside, almost like there smallfry compared to your future project!
