help stator testing
micricco
help stator testing
Post by micricco »
can someone please help,can you test your stator as per manual please and let me know what you get.
reason i ask i have 3 stators,just bought the 3rd came off good runner,no reason to doubt.
heres the readings that i got,that need to double check cos it dont make sense!!
stator 1: exciter coil white/red 14.2 black/red 144.2 stator yellow/yellow 37 and 23.7
stator 2 exciter white/red 9.2 black/red 144.9 stator yellow 6.2 and 6
stator 3 exciter white/red 37.9 black/red 192.5 stator yellow 15 and 15
if i have read it right exciter white/red should read 2-7 ohms black/red should read 100-200 ohms and the stator yellow should read 0.3-1 ohms
please help and let me know what you get when you test yours cheers mick thanks
micricco
stator
Post by micricco »
nobody??????? :shock:
Bikemike
Post by Bikemike »
Give people a chance :shock:
It's not a five minute job and you only posted this morning, most people will have been at work.
I would help but mine is buried at the back of the garage. Again.
I'm sure someone will be along with the answer soon.
Edited due to damn autospell on phone changing wot I rote!
micricco
stator
Post by micricco »
anyone had a chance to test at all please,just need a comparison with someone elses before i change my stator over any help much appreciated cheers mick
Ask Janbros if he can help.
Mick the reading between any 2 yellow leads should be 0.3 to 1.0 ohm - so
this means you need to take 3 readings
Readings outside this range means a faulty stator
Hope this helps
micricco
stator
Post by micricco »
thats what i thought tested all the yellows and are outside the readings,just wanted to see what other people got reading wise.i got a stator of good running bike but even thats out of range
i'll test mine tomorrow im out in the shed but if you haven't heard by midday then mail me ive forgot cheers and patience is a virtue we are all here to help just not at the click of your fingers no offence cheers wayne.
micricco
stator
Post by micricco »
thanks that would be much appreciated,i dont mean to be pushy am just frustrated because i tested as per manual yet it doesnt add up,according to the figures all 3 are u/s including the one i just but that came off a good running bike from a respectable forum member.am interested to see if anyone elses doesnt read right as per specs.i know its not a long job as i tested the one currently fitted to bike cheers
no worries i know i tested everything on my bike once, yeah i'll test it just have to read up on the forum to refresh the green antimatter cheers wayne.
micricco
stator
Post by micricco »
thanks wayne
I'll test one tomorow.
But I know from experience :
* that measuring resistance alone is not enough, everything can be in the right ball-park and still the stator can be bad (vibrations/heat/... from the engine)
* resistance from the 3 spools for the ignition isn't that important. originaly there are 3 wires, I rebuild once one with 2 wires, couldn't get enough wire on it to have enough resistance, but still it worked perfect.
In my mind, only way to be sure about the stator, is replacing it with a known good one, and placing the faulty one on another engine/bike to double check.
sorry for the delay :oops:
I've measured 4 :
nr 4 is the one I rewired. it's imposible to get as much wire on it as original. I used 2 wires in stead off 3 original (there are 3 wires wired parallel on the 3 windings for the ignition,) (but with the 2 wires about the same rescistance as the 3 original over a comparable length), but it still worked fine.
micricco
stator
Post by micricco »
thanks janbros,that helps very much appreciated,confirms that all 3 are outside spec cheers mick
just now I looked at your fugures.
what's very odd is that your yellow's are so high. it's very unusual that they fail, and even more odd that you should have 3 of them.
normaly if stator's fail, the problem is with the red/black/white. On the one I rewired, it was the black/red combination.
looking at your numbers, I'm not so sure they are all bust. your nr 3 probably is. the yellow's are not needed to run the engine if you have a good battery. I'd try both of them with the yellow wires disconnected and see if you have a good spark. If so, refit the yellow's, but have a good look at what voltage is being sent to the battery.
btw : I found out I had mixed up some numbers, so did it again with better equipment. new file is in my previous post.
