bolt
I think they are same dimensions as those on fork lower triple clamp (chrome vs black though - heat)
at a pinch maybe use one off them and get stainless/pro-bolt for clamps (budget)
the number on bolt head gives indication of grade/strength
stretch bolts mostly used on items like con-rod big ends (4T) to achieve exact tolerance on bearing shells etc - one time use as said
all bolts will eventually stretch (non-return to original dimension) if stressed past the 'elastic limit' of the material
