I've had a couple of problems with the electrics on the KR1s, neutral light, temp gauge, which turned out to be down to bad earth connections.
Now though I have an oil light that wont go off.
I think it's the switch, but I havn't got a spare to check, or is there something I'm missing.
Yes there's oil in the tank.
Oil light
does it go off when the bike is not in neutral ? because the oil light always goes on if you put the gearbox in neutral : it's a way off testing the bulb so you know it work's and it will light up when the oil level is low
for the switch and light : check manual page 15-25 and 15-27
