Gearbox/right side - am I being blonde?
Post by scooble »
I am about to put my engine back together and I wanted to check with the manual and the fiches the order in which things go back together.
My question is the idler gear arrangement. I can see a picture of it in the manual, but I can not find it on any of the micro fiches.
The picture below shows it assembled;
You can see in the inset picture that it marks item 'E' as washers - however, I cant see to find a diagram of this arrangement to show the quantity and part number for these washers. Although I can clearly see where the retainer (Part C) goes, I can't find this on the fiches either.
Am I missing something obvious?
mj43
Post by mj43 »
Trisha
There should be a washer gearbox side, the idler gear, another washer and the circlip.
The parts fiche B8 shows the info you want on the idler gear and B13/14 the oil feed pipe?
Regards
Mark
Scooble, it's on page B8 of the KR-1S micro fishes, together with the kick-start :wink:
Post by scooble »
I see, thanks guys, I found the fiche, however is the arrangement - washer gearbox side, needle bearing, circlip, gearbox wall, washer, idler gear, washer and then circlip?
