Its been a bit cold so i havent done much but the dry build is still going ok just the usual problems with spacing as i want to use as many original and period parts as i can. I just want it to look updated not like another bike.
Besides i have never seen the point of making an RGV or KR or whatever look like whatever you pinched the fairing off, i mean why not just buy one of those?
No electrics or anything fitted yet i want to be sure the chassis has no issues first. The swingarm uses the centre stand mount as a pivot point so i got a longer bolt and have done it so it screws into the mounts on one side and has a nut on aswell to lock it in place. A bit belt and braces maybe but better safe than sorry. I sorted the risers with some billet ones and altered the holes to use four bolts as i dont want them welded on.
so i dropped on the bodywork loose to see if my silver frame and bare alloy bits will work and give myself an incentive. It always helps when you can see a bike.
Im thinking it will work and i might even get away with a standard paint job
but im not sure yet the candy red with black speed blocks might still win
Anyway it looks like this at the mo, the pipes are Micron GP
