need three way throttle/oil cable junction
Number 54012-1246
- Top-shaggy
http://www.remarcables.com.au/Motorcycl ... le473.aspx
Says item in stock - may be worth checking first
Hmm. Same part-number, but says it's for a '76-79 Z750 B1-B4. Seems unlikely that they'd share a common part ?Top-shaggy wrote:http://www.remarcables.com.au/Motorcycl ... le473.aspx
If you have an old cable, it should be possible to get new inners made.
Yamaha RD350LC,
Suzuki GSX-R750RK & RB50 Gag.
Yamaha RD350LC,
cable splitter
try the cable splitter from one of the KH series kawkas they use the same idea
1984 Kawasaki KR250A
2 Smokey and they bandit
turns out the throttle cable is boogered up too, so I'm going to see what this outfit can do for me.
StrokerBoy wrote:Hmm. Same part-number, but says it's for a '76-79 Z750 B1-B4. Seems unlikely that they'd share a common part ?Top-shaggy wrote:http://www.remarcables.com.au/Motorcycl ... le473.aspx
Says item in stock - may be worth checking first![]()
cables
try these people www.venhill.co.uk
Remar Cables !!!
got the cables , they are perfect!
=D> thanks
=D> thanks
- the KR kid
- Top-shaggy
Re: Remar Cables !!!
It was worth a punt - pleased you got the cables you neededpepsi wrote:got the cables , they are perfect!
=D> thanks
