Fitting F3 valves in KR1 barrels
Gazjen
Post by Gazjen »
I've got a set of F3 valves on there way and wondered what the best course of action was. Is it best to fit two F3 valves in the outer ports and two S valves into the inner ports? If that's the case I will be after 1 S valve
I stripped the engine yesterday and all but one of the valves were set wrong 1 snapped as I removed it and it turns out I have 1 S valve and 3 kr1 valves, I've read a little about matching the ports to the S valves but does anyone have any pics? Only the two outer valves seem to match up correctly with the ports is this normal?
Any help greatly received
Also is there a post anywhere regarding basic tuning just something to give it a but more power without ruining the ride or reliability?
Gaz.
Re: Fitting F3 valves in KR1 barrels
Gazjen wrote:I've got a set of F3 valves on there way and wondered what the best course of action was.
[url]lhttp://www.kr-1s.co.uk/forum/viewtopic.php?t=7 ... it++valves[/url] :wink:
Gaz.
lot's, just use the search.
Look in the engine section on flowing your crank cases.
That's the best, easiest and cheapest way to reliably gain about 10% extra power if done correctly.
