need a photo of the left side main wiring harness route
Hi, Having a problem figuring out the main wiring harness routing anybody have a photo? 1985 KR250
- the KR kid
yea I saved that sticker when I painted the frame , nice photos, they will help, I can't find the ones I took before the dissassembly
I can't seem to get the harness to lay right , it goes under the frame , above the hose, along side of the control box, with connectors above the box? And the box has its wires facing towards the rear?
- the KR kid
Yes, the wires from the box face the rear, and it is tied to the fairing mount bracket in pic 3 underneath. From there it goes under the tank above the rear cylinder. I assume you still have the bracket that screws to the headstock and the front tie, as in pics 1 & 2?
GS750B
KH250B5
GS750B
KH250B5
- the KR kid
It takes a left turn into the fairing and runs just above the indicator, tied to the fairing frame. Then runs behind the headlight into the right side of the fairing past the other indicator. the pics show the route it takes; hope they help!
GS750B
KH250B5
GS750B
KH250B5
- the KR kid
- the KR kid
Actually, I really want to get back to where I was 10 years ago, fettling the KR(s) every weekend and posting regular updates to keep you all informed and/or entertained.the KR kid wrote:Strokerboy has been trying to get out of running his site for years!
I've got too many other distractions these days.
But ... I get my forks back tomorrow so fingers crossed for an MOT before Easter.
Yamaha RD350LC,
Suzuki GSX-R750RK & RB50 Gag.
Yamaha RD350LC,
- the KR kid
The L/H loop has the R/H switchgear wiring run through it only.
Running OUTSIDE the loop on the L/H side are wiring looms for the rear brake light, L/H switchgear, and ignition switch.
The clutch and choke cables run up from under the lower fork yoke.
The R/H loop has the throttle cable running through it only. This cable also goes through the plastic loop screwed to the frame.
GS750B
KH250B5
GS750B
KH250B5
