need a photo of the left side main wiring harness route
Posted: Mon Mar 18, 2013 10:40 pm
by pepsi
Hi, Having a problem figuring out the main wiring harness routing anybody have a photo? 1985 KR250
Posted: Tue Mar 19, 2013 4:07 pm
by the KR kid
From the headstock to under the tank pics. Sorry they're a bit dark!
Have you got a decal on the top left side frame rail under the tank, which also shows some routing of wires?
Posted: Tue Mar 19, 2013 8:53 pm
by pepsi
yea I saved that sticker when I painted the frame , nice photos, they will help, I can't find the ones I took before the dissassembly :roll:
I can't seem to get the harness to lay right , it goes under the frame , above the hose, along side of the control box, with connectors above the box? And the box has its wires facing towards the rear?
Posted: Tue Mar 19, 2013 9:05 pm
by the KR kid
Yes, the wires from the box face the rear, and it is tied to the fairing mount bracket in pic 3 underneath. From there it goes under the tank above the rear cylinder. I assume you still have the bracket that screws to the headstock and the front tie, as in pics 1 & 2?
Posted: Wed Mar 20, 2013 12:36 pm
by pepsi
but how does the main big bundle of wires run along the box and up to the headlight area?
Posted: Wed Mar 20, 2013 2:03 pm
by the KR kid
It takes a left turn into the fairing and runs just above the indicator, tied to the fairing frame. Then runs behind the headlight into the right side of the fairing past the other indicator. the pics show the route it takes; hope they help!
Posted: Wed Mar 20, 2013 10:54 pm
by StrokerBoy
Top job Gary. =D> Fancy taking over the running of my site ?... :wink:
Posted: Thu Mar 21, 2013 9:16 am
by the KR kid
Thanks Tim, :D and er, no thanks! =; :lol:
Posted: Thu Mar 21, 2013 8:34 pm
by pepsi
Thanks O:) !
Whats the deal with your site, ,,I wonder.... :-k :-k :-k
StrokerBoy wrote:Top job Gary. =D> Fancy taking over the running of my site ?... :wink:
Posted: Thu Mar 21, 2013 9:27 pm
by the KR kid
Pepsi, have you got it sorted now?
Strokerboy has been trying to get out of running his site for years! :lol:
think so
Posted: Thu Mar 21, 2013 10:28 pm
by pepsi
I think I have it figured out, , gota couple of bullet connectors that are puzzlin me a little
thanks again
Posted: Fri Mar 22, 2013 8:42 pm
by StrokerBoy
the KR kid wrote:Strokerboy has been trying to get out of running his site for years! :lol:
Actually, I really want to get back to where I was 10 years ago, fettling the KR(s) every weekend and posting regular updates to keep you all informed and/or entertained.
I've got too many other distractions these days. #-o
But ... I get my forks back tomorrow so fingers crossed for an MOT before Easter. :mrgreen:
Posted: Mon Mar 25, 2013 12:53 pm
by pepsi
what is threaded through the left and right side wire hoops attached to the fairing mount on the frame?
Posted: Wed Mar 27, 2013 4:20 pm
by the KR kid
The L/H loop has the R/H switchgear wiring run through it only.
Running OUTSIDE the loop on the L/H side are wiring looms for the rear brake light, L/H switchgear, and ignition switch.
The clutch and choke cables run up from under the lower fork yoke.
The R/H loop has the throttle cable running through it only. This cable also goes through the plastic loop screwed to the frame.
Posted: Wed Mar 27, 2013 9:20 pm
by pepsi
very well done thank you very much! O:)
