Right indicator does not work!
Peter4180
Post by Peter4180 »
After putting my KR1-S together the indicator to the right side does not work. To the left everything works fine but to the right only the rear lights up but not flashing and no light in the front indicator.
If I change the wiring in front connecting the right indicator to the left's wiring - it works...
Advice needed???
you'll have a broken wire in the front right indicator circuit. time to dig out the wiring diagram and your resistance measuring device (hou you call a multi-meter in english ?) and dig in :wink:
Peter4180
Post by Peter4180 »
Thank you - had hoped for some magical words... Will have to dig in....
Very much appreciated
Peter
easiest thing to do first is check that 12V arrives at the indicator, and take a wire and connect the "-" from the indicator to the chassis/battery minus :wink:
