300cc Kr1s Engine build
Re: 300cc Kr1s Engine build
are those pistons on backwards?
Looks like they are Danny.
Did not notice the holes on the piston facing the back when they should be to the front.
Doesn’t matter as it’s going to be stripped down and new pistons fitted
podman
Post by podman »
Very nice indeed, ive seen Garys going at full chat and they do seem to go well...and sound proper 2T fit...
podman
Post by podman »
Fab...
Is Mick Abbey the person who is going to build the pipes & set it up afterwards?
Small end bearing
here is a link to partial cross reference gudgeon pin dimensions against some common JDM OEM numbers
http://www.tkrj.co.jp/product/m-se-bearing.html
What I meant about the pipes janbros was that the pipes are being made by mick abbey who is tuning the top end. And then setting it up on the dyno.
That’s why I said it will be the first time it would of been done,
I know you and fred have made pipes before, so may of got it a bit wrong.
Thanks for the link Danny.
I have found one bearing that may do it from the list you sent. Would be easier than fitting washers.
Lots of goodies there John 8)
E3 plugs ,aren’t they the plugs with the fancy electrodes, bit like marine plugs? Looks like everything on your sparks from generation, timing, connection and firing will be spot on. Looking forward to hearing how its going.
Hi Steve,
Been running mine with all those parts for over 4 years now, never missed a beat, never fouled a plug in all that time, and had quite a few blasts on Mick Abbeys dyno.
Bernie 8)
I didnt spot the electrical wizardry you had employed in your build Bernie. I guess I looked more at the finishing and those lovely Lomas pipes.
Post by scooble »
Johnfarley wrote: Sun Apr 21, 2019 11:52 am Now got my 34 mil Stuffers for the vforce3 👍picture shows the big difference between the std 28 mil ones.
...can you tell me what the VFORCE part number is for those stuffers?
Post by Gerrit »
I'm not sure whether V-Force actually list those stuffers, Scooble, but BDK certainly do!
This is where all the magic is happening at the moment. .
The Twostroke Wizard is working hard....
Post by Gerrit »
I wonder what the bore is of these cylinders- 60-61 mm?
