Backfiring Part2
- Light Smoker
Backfiring Part2
Help, i fear it may not be long until i'm sectioned under the mental health act unless i can fix this cursed kr1s. Carrying on from my previous topic of backfiring. I have now replaced the cdi and double checked the new stator, as per the manual and still no go. Now i am getting intermittant sparking. As it's a wasted spark system i'm assuming it should spark simultaniously, but mine sparks simultaniously then on the right then left. just randomly and then sometimes not at all. I was convinced it was cdi problems as everything else has been changed. I am now completely out of ideas but refuse to let this swine get the better of me. Any ideas apart from burn it? Cheers.
- mr_bungholeo
- ScottaKR
Re: Backfiring Part2
The intermitant spark youve described makes me think it's the coil, especially the fact that you say it goes from both to one or the other.Trxbadger wrote: Now i am getting intermittant sparking. As it's a wasted spark system i'm assuming it should spark simultaniously, but mine sparks simultaniously then on the right then left. just randomly and then sometimes not at all.
I'd try to find a known good coil from a running bike if someone will lend you one for testing.
Good luck.
Cheers, Scott.
KR250 Tandem Twin (Naked)
- corky
