The quesion i need is after you have put the end caps in the ends of the pivot bolt spindle and tightened in the frame to the correct torque,how tight or loose does the swinger need to be ?
KR1S swingarm end cap clearance
I have a KR1S swinger in an RD frame
- SHimmer45
from when i mounted my swinger i just tightened it down and it rotates on the spindle. if its too tight then you will possibly stretch the spindle.
if its too loose i would guess that it would generally make the handling sloppy and wear any linkages as well
post doesnt really help you
just some ideas
Red Devil 777
