True or False?
Laurus
- Newbie
True or False?
Someone told me that there are two kinds of baskets for the cilinderhead, a metal one and a rubber one, true or false? If true, what are the differences between these two? How do I know what one to use?
Thanks in regard.
Laurens
Thanks in regard.
Laurens
- the-elf
I'm not sure what you mean by Basket? Can you post a picture of the part in question please?
Re: True or False?
You must mean gasket, right?Laurus wrote:Someone told me that there are two kinds of baskets for the cilinderhead, a metal one and a rubber one, true or false?
Just use the original (metal) Kwak ones and apply some bond on both sides.
cheers,
Laurus
- Newbie
Laurus
- Newbie
Huhm, interesting, what does such a modify mean?
It's about this bike, a '94 kr1s with only 7000km...:
http://img149.imageshack.us/i/10296937.jpg/
With this head:
http://img513.imageshack.us/i/1001297.jpg/
http://img232.imageshack.us/i/1001298.jpg/
http://img149.imageshack.us/i/1001296.jpg/
Unfortunately, can't get the pictures working properly.
With this head:
Looks like a normal head to me?!
Is that the bike that used to belong to Jim (ZL900 from motor-forum.nl)?
If it is, how come you had to take the head off again, he did repair the one barrel, didn't he?
cheers,
cheers,
Bikemike
Or maybe notBikemike wrote:post a picture of it and we'll be able to tell for sure.
Looks like a mark or shallow groove in the head where an O ring would sit but O ringed heads I have seen have a much deeper machined groove.
I'm sure a couple of people on here have had O ringed heads (Jan?) and will be able to tell.
Mike
Edited due to getting up at 5am and brain now asleep
Laurus
- Newbie
Yes, it's the former bike of Jim indeed. He didn't repair the one barrel but sold it with a broken one (and piston)... So I bought it in pieces, only have to fix the barrel and hope it will be fine by then..Charles wrote:Looks like a normal head to me?!
cheers,
damaged barrels repaired...
?cast iron/steel cylinder liners pressed in - alternative option to reconditioning electrofusion plated bores ?
what do the undersides of the barrel look like? will be easier to determine if it has been linered from that view.
