new to the site and new prodject ,so hello and help
- Newbie
just got my hands on a F reg kr1 or kr1s not sure which one and its using water somewhere ,had a look at the oil level screen and it doesnt seem to be milky would it go into crank ? or gear box ,not sure as i am used to enduro/motocross bikes .any way i can tell ,off roaders its usualy water pump shaft/seal ,headgasket or cracked head is it the same on the kr1/s any help appreciated thanks
- the-elf
There is a hole in the crankcase behind the pump which is supposed to stop the water getting into the box should the waterpump seal fail (not always the case as they can bloke up).
Other things that can cause water loss is a blown head or base gasket allowing water into the cylinder or out of the engine. or a leaking temperature gauge sender.
The worse case is a cracked cylinder/head (not very common on a standard engine).
- Newbie
nice one elf , it was the head gasket that was the problem so i have just spent two hours with a flat piece of iron and some valve grinding paste , flattening the barrels and head ,should be ok now , just wanted to know why there is two base gaskets on each side ? plus has anyone seen or drilled a hole in there oil filler cap on the clutch (mine has been ) any idea why . cheers
- Newbie
- the-elf
Race regs say it has to be lock wired into place.upyourkiltbatman wrote:why do they drill it for ?
- Newbie
is the cap drilled through vertically???? oh dear, if you mean what i think you mean then a previous bodge artist has indeed thought for some reason that the gearbox needs a pressure release/breather!!!!!! i can only assume the crank seals have failed and sir bodgealot wants to keep her running.
if the drilling is how elf describe then this is purely a safety requirement needed for race scrutineers. prevents the cap coming loose and leaving oil everywhere. i hope its the latter. have never seen anything like the former but this can only mean one thing.
- Newbie
