vibration problems
edgar90
vibration problems
Post by edgar90 »
hi there!!!
my bike has its engine recently rebuilt,and it works "fine"
but when i increase rpms the entire bike iniciates to vibrate,everything on the bike vibrates,and everything beggins to sound ,but when its in idle speed it doesnt vibrate. \:D/
do your bikes have the same"problem" or mine has something bad??
hope you can help me...
[-o<
edgar90
vibration problems
Post by edgar90 »
forgot to tell you
ill post a video as soon as i get one
balancer
if your crankshaft has been removed...
might need to check the Balance Shaft (bolted onto front of cases behind left exhaust header)
there is alignment marks/punch marks - the gears have to be aligned to the center gear on the crankshaft
http://www.kr-1s.co.uk/manual/Part%2008 ... ission.pdf
Blancer Shaft Installation
Align the punch marks on the balancer gear and crankshaft gear.
[ see page 12 (page 8-12 of manual Crankshaft/Transmission) ]
maybe you dont have one - previous owner removed??
if there wasnt one it is probably not bad because the first TZR doesnt have one(?)
BUT if the balancer is out of phase with the crank that may be your issue - worse than not having one
edgar90
Post by edgar90 »
i am sure its aligned,because i personally rebuilt this engine
buuuuuuuuuuuuuuut...
don you think my crank needs to be balanced????
because is the only thing i have left as a choice to solve this problem
thanks again
Tambo
Post by Tambo »
You won't have to balance the crank as such, but pressed cranks can twist out of alignment - haven't seen it mentioned on here though, so hopefully not a KR issue.
Could be one cylinder that's not running correctly at higher speed ?? I'd do the usual easy things first - plugs, clean the carbs etc. Are your reeds in good condition, and closing properly ? After that, worth double checking the balance position.
Good luck.
edgar90
Post by edgar90 »
ok thank you everyone
please if you have any other idea please let me know,so that i will check the easiest
thanks again
even when one cylinder is not working at all, that wouldn't produce vibrations.
I'de check the balancer shaft first :idea: I had it one tooth wrong one time, and you can't believe how much vibrations that creates.
Cliff
Post by Cliff »
Loose engine mounting bolts? You mentioned it had been rebuilt.
