wont stay in second
- ScottaKR
wont stay in second
Took the KR1 out for a run around the block today after sorting out the running issues, got her into second and decided to open it up but as soon as it hit the powerband she jumped into nuetral. Tried it again a few times but it does it every time.
Any ideas people?
Any ideas people?
KR250 Tandem Twin (Naked)
250 drummie
Does it do it in the other gears if so then I would say that your selector drum is not engaging fully. Check the position of your gear lever and make sure there is nothing fouling it. If all is well with the lever you will have to remove the clutch cover and inspect the arm on the drum. These can get damaged by muppets riding them in a past life. I have seen them snapped in half.
- ScottaKR
TwoStroke Institute
Soap and water for you ! Ronded dogs are a cinch to fix and cheap as well. $75AUD to undercut dog and mating slot. Even a custom gear ratio is $250 for one or $500 for both driver and driven gears.I'll check the gear lever, but if there's no problems there I think I'll just throw another box in it. Otherwise I could be chaseing this one for ages I think.
crochet & croquet
- Tambo
I wouldn't go changing a whole box yet - you should be able to see the wear causing the problem on the engagement of the selector drum, or the dogs of the gear (as per Jan & Drummie). My money is on either of these, although there's an outside chance it could be gear shaft bearing that's gone, but that would be noisy, and cause lots of shifting issuesScottaKR wrote:Thanks guys.
Keep at it !! Good luck.
Sheik Yerbouti
- ScottaKR
Sheik Yerbouti wrote:Yeah sounds like drive dogs, TSI is right, its a pretty simple job to undercut them. But we used to charge $100![]()
I'd go with the $75 option.
Or I can just go though the spares I have here and dig out a good one.
Then I can spend the $75 I save on some Scotch to help ring in the new year.
Sheik Yerbouti
Sheik Yerbouti
symtec23
- Light Smoker
gear selection issues
My kr1 would do this and was also damm impossible to shift down from second to first. Ended up being a flogged out shift drum and dammaged dog teeth on second gear. Once I replaced complete box, it changes gears as smooth as butter. If you have a spare box, just swap it out as it will only get worse.
- ScottaKR
Re: gear selection issues
Yeah, that's what I ended up doing this arvo. It no longer jumps out of gear, and it shifts up & down really well, but it's still not perfect. When the engines at idle (or below about 2k) in neutral, it sounds like someones dumped a bag of marbles in there.symtec23 wrote:My kr1 would do this and was also damm impossible to shift down from second to first. Ended up being a flogged out shift drum and dammaged dog teeth on second gear. Once I replaced complete box, it changes gears as smooth as butter. If you have a spare box, just swap it out as it will only get worse.
Maybe I can make one good gearbox out of the two using the gears from the first box and the selector/shift mechanism from the second box.
+2 on that scott,mine did exactly the same.Does'nt cost any thing to tighten a bolt.JanBros wrote:Scott, sounds more like the flywheel is just a teeny bit loose.
better check that before you take out the gearbox again.
and if not that, is the cluch-basket beaaring still ok ?
