wont stay in second
wont stay in second
Took the KR1 out for a run around the block today after sorting out the running issues, got her into second and decided to open it up but as soon as it hit the powerband she jumped into nuetral. Tried it again a few times but it does it every time.
Any ideas people?
250 drummie
Post by 250 drummie »
Does it do it in the other gears if so then I would say that your selector drum is not engaging fully. Check the position of your gear lever and make sure there is nothing fouling it. If all is well with the lever you will have to remove the clutch cover and inspect the arm on the drum. These can get damaged by muppets riding them in a past life. I have seen them snapped in half.
or second gear is worn out. not the gear itself but the "blocks" on the side of the sliding gear-sprocket that hook into the fixed sprocket next to it, haven worn and are now rounded.
Thanks guys.
I'll check the gear lever, but if there's no problems there I think I'll just throw another box in it. Otherwise I could be chaseing this one for ages I think. :-k
TwoStroke Institute
Post by TwoStroke Institute »
Soap and water for you ! Ronded dogs are a cinch to fix and cheap as well. $75AUD to undercut dog and mating slot. Even a custom gear ratio is $250 for one or $500 for both driver and driven gears.
crochet & croquet
Tambo
Post by Tambo »
ScottaKR wrote:Thanks guys.
I wouldn't go changing a whole box yet - you should be able to see the wear causing the problem on the engagement of the selector drum, or the dogs of the gear (as per Jan & Drummie). My money is on either of these, although there's an outside chance it could be gear shaft bearing that's gone, but that would be noisy, and cause lots of shifting issues 8-[
Keep at it !! Good luck.
Sheik Yerbouti
Post by Sheik Yerbouti »
Yeah sounds like drive dogs, TSI is right, its a pretty simple job to undercut them. But we used to charge $100 :roll:
I'd go with the $75 option.
Sheik Yerbouti wrote:Yeah sounds like drive dogs, TSI is right, its a pretty simple job to undercut them. But we used to charge $100 :roll:
:-k :-k
Or I can just go though the spares I have here and dig out a good one.
Then I can spend the $75 I save on some Scotch to help ring in the new year. :mrgreen: \:D/ \:D/
Sheik Yerbouti
I can't argue with that. Settle yerself doon with a nice bottle of Dimple then... :P
Sheik Yerbouti
Would a worn selector drum also cause it to not want to downshift properly?
symtec23
gear selection issues
Post by symtec23 »
My kr1 would do this and was also damm impossible to shift down from second to first. Ended up being a flogged out shift drum and dammaged dog teeth on second gear. Once I replaced complete box, it changes gears as smooth as butter. If you have a spare box, just swap it out as it will only get worse.
Re: gear selection issues
symtec23 wrote:My kr1 would do this and was also damm impossible to shift down from second to first. Ended up being a flogged out shift drum and dammaged dog teeth on second gear. Once I replaced complete box, it changes gears as smooth as butter. If you have a spare box, just swap it out as it will only get worse.
Yeah, that's what I ended up doing this arvo. It no longer jumps out of gear, and it shifts up & down really well, but it's still not perfect. When the engines at idle (or below about 2k) in neutral, it sounds like someones dumped a bag of marbles in there. :shock: Put it in gear or pick the revs up and the noise disapears completely. Not sure why it's only under those circumstances (shagged bearings perhaps?), but I think it may have to come out.
Maybe I can make one good gearbox out of the two using the gears from the first box and the selector/shift mechanism from the second box. :roll:
Scott, sounds more like the flywheel is just a teeny bit loose.
better check that before you take out the gearbox again.
and if not that, is the cluch-basket beaaring still ok ?
JanBros wrote:Scott, sounds more like the flywheel is just a teeny bit loose.
+2 on that scott,mine did exactly the same.Does'nt cost any thing to tighten a bolt.
