hi everyone,i need some kr1s crankshaft pics to see if the centre gear is timed correctly.
i mean a pic that shows me the punch marks and the position of conrods
hope you guys can help me
thanks
anyone got crank pics?
- Light Smoker
THIS IS ONLY A GUESS
at (left cylinder) bottom dead centre, the balance shaft lobe (left most one) should be at its upper most point,
this thinking would indicate that when the pistons are mid stroke (left piston on way up) the left balance lobe should be front most
try , DIXON, he has most recent pics available
viewtopic.php?t=5772
- Light Smoker
- ScottaKR
Yeah, I think it probably is.edgar90 wrote:thanks a lot guys
mine has the punch marks on the opposite side,i mean left conrod(upper in pic) is in the same position but has the marks on the rear side(see pic from Jan)
can this be my problem??
i mean vibration
thanks a lot again
Your balance shaft timing will be 180deg out of phase. Just put a new mark on the tooth 180deg around from the origional one, and put it together using the new mark. Should see your engine running nice and smooth after that.
Good luck, Scott.
KR250 Tandem Twin (Naked)
- Light Smoker
