Rik Ring Kit - Oil Ring??
Kr1s1991h
Post by Kr1s1991h »
I bought some replacement pistons (Makita) and a set of rings, believe they are Rik, in the kit there are two normal 'round' rings and one multi-sided ring (oil ring??) can anyone enlighten me to what or where the multi-sided one is for.
Is the bin a good answer??
are you sure you have the right rings ?? never heard off a set off rings where they put too much in :?
picture ?
Could it be the expander ring ?
The LC Boys leave it out on their Mitaka's
KR1S91
Post by KR1S91 »
That sounds like the "expander" ring from what u are describing. It fits in the bottom ring groove on the piston before fitting the piston ring.
Hope this helps
Scott
twostrokesmoker
Post by twostrokesmoker »
Could be a "universal" kit for 2 or 4 stroke's :-k ie the third ring would be your scraper ring ????
someone will probably come on & say im talking through my "ring" :roll:
mgtkr1
Post by mgtkr1 »
expander ring be sounds of it mate
250 drummie
Post by 250 drummie »
All the expander rings I ever came across are a wave type shape and are really thin. The RDs have them but I never fit them because they can break being so thin and then they overlap each other and jam the ring itself. I never had an issue leaving them in the box. Less weight too :roll: every bit helps
spannerman
Post by spannerman »
it is the expander i had to ask the same question from kev at ard, he said it didn't matter if you bothered or not but road use he would and trackday he wouldn't bother.
i didnt use them and they have been no trouble but i did fit them under the bottom ring in my mates 2ma and it also has been no trouble.
ade.
on the pipe!!!
Kr1s1991h
Post by Kr1s1991h »
Many thanks for the replies, as correctly suggested it is the expander ring, which fits underneath the 'normal' lower ring.
Thanks again guys! :wink:
