I bought some replacement pistons (Makita) and a set of rings, believe they are Rik, in the kit there are two normal 'round' rings and one multi-sided ring (oil ring??) can anyone enlighten me to what or where the multi-sided one is for.
Could be a "universal" kit for 2 or 4 stroke's ie the third ring would be your scraper ring ????
someone will probably come on & say im talking through my "ring"
All the expander rings I ever came across are a wave type shape and are really thin. The RDs have them but I never fit them because they can break being so thin and then they overlap each other and jam the ring itself. I never had an issue leaving them in the box. Less weight too every bit helps
it is the expander i had to ask the same question from kev at ard, he said it didn't matter if you bothered or not but road use he would and trackday he wouldn't bother.
i didnt use them and they have been no trouble but i did fit them under the bottom ring in my mates 2ma and it also has been no trouble.
ade.
