I removed the float bowl to check the condition of the carb. Removing the float bowl was awkward - that angled tube fixed to the bottom of the bowl seemed to snag on the float and the main jet assembly.
And refitting the float bowl was very awkward - the angled pipe kept snagging on the parts .... Is it just me or is there a technique to removing and fitting the float bowl ?
Holding carb upside down and once float bowl screws are removed,it 's a case of cocking the bowl to one side as you remove it
Bit of practice and you will be an expert
