If there are none I will start to replate mine, as they aren't in too bad a condition, I'm not paying £5 per bolt either
disc bolts
SP_BOTT
disc bolts
Hi did a search which came with a few results, are there alternative disc bolts available at a reasonable price, I don't really like stainless, but just wonderd if another manufacturers fit, have to be aware of the shoulder on this bike, (unlike the RD's I'm used to)
any one got an alternative please?
the heads are low profile so the shoulder gives a bit of space for the socket recess
on a technical note, the shoulder carries SHEAR force from the rotor to the hub.
The threading process causes stress raising effectively weaking the design (of a round bar)
so the best design is a thicker shoulder carrying the shear not across the threads...
...however alot of standard (older) Yamaha ones (and BMW, some h***a front and Aprilia, Ducatis - see Probolt profiles) have NO shoulder and have no problems
but if you had the choice why not stainless - rotor bolts are in a corrosion prone area - seized rotor bolts is common problem
http://www.tastynuts.com/file.php?filen ... _Bolts.pdf
if you use Probolt theyre on £4.39 each
cheaper than Ti
