exhaust mount bottom bracket
So what are we doing?
Are we going to have a whip around and all put a few quid in and end up with some spares?
I'm game, over to you guys (and Gals)
Bernie :D
I might have a solution to the bottom bracket problem :-k
I was sorting through some parts today when I came across some old exhaust mounts.They are the same type as the rear exhaust mounts.They where on dozens of different Kawasakis so they will be easy to get hold of.
I just thought that might work if it was'nt so deep.So I've cut one down by 5mm and as it takes a M10 bolt I've sleeved it out with a wee bit of silicone rubber tube to take the M8 mounting bolt.
Put it all together and its a nice fit.If there are any problems with heat affecting the rubber sleeve,I'll just sleeve it out with steel.
What d'ya reckon :-k
Post by SHimmer45 »
been working on making up an insert for these brackets hopefully be able to post a pic of the end result.
possibly might even be able to supply a few depending on how they work.
boggy
bushes
Post by boggy »
Hi all,If someone can point me in the right direction for material i may be able to turn some bushes for you to try out.
Post by SHimmer45 »
hi,
the metal insert required has an ID of 8mm which is then pushed in a rubber bush, i have some inserts to test over the weekend.
i have access to a couple of lathe's at the school i work at and will most likely get someone to show me how to use them :mrgreen:
Post by SHimmer45 »
ok, kit has been made up and fits spot on into the bracket.
going to be posting a pic shortly.
i think it is viable to supply kits to those interested in refurbing existing brackets
Good man :D
Post by SHimmer45 »
apologies for the delay in getting some pictures up.
sorry for the slightly iffy quality but you should get the idea.
was looking at possibly refurbing a couple if people are interested
pics are located Exhaust Bracket
this is my own one which is rather shabby will look better with a lick of paint :D
takes the M8 bolt without the need for sleeve's or bushes
Any idea of the cost to refurb?
Bernie :D
Post by SHimmer45 »
most likely around £10-£15
need to make sure i can still source the parts that i refurbed mine with.
shouldnt be a big problem.
