anyone got an Ignitech race ignition?
mj43
Post by mj43 »
TwoStroke Institute wrote:...The fully open and full closed runs is not the way to do it either....
As the KR power valve is effectively a switch what is the point of testing in between open or closed?
TwoStroke Institute
Post by TwoStroke Institute »
I never said to test in between open and closed, and doing full open and full closed tests does not provide the correct effective open/close point.
Jan you will still split timing on a parallel twin.
crochet & croquet
mj43
Post by mj43 »
So how do you recommend testing a KR power valve system if you are not meant to test in between open and closed but open and closed is wrong?
TwoStroke Institute wrote: Jan you will still split timing on a parallel twin.
what do you mean with "split" ?
a paralel twin with matching cylindres/tuning surely requires the same timing for both no ?
TwoStroke Institute
No requires split timing between the cylinders, parallel, V or inline tandem timing still gets split. Split I mean that cylinders run different ignition curves.
MJ I don't know how to make it any simpler, than doing a full open then a full closed runs and comparing the 2, is not the best way to arrive at the correct effective open/close point (depending on your terminology).
crochet & croquet
TwoStroke Institute
Have you got the Ignitech fired up yet? :lol:
crochet & croquet
Not yet and I probably won't get round to looking at it for another month. Work on the bike has been slow, but I will be picking up the pace on the rebuild very soon.
Got the bike fired up today with the new ignition.
Need to work on the configuration a bit, but all seems well so far.
TwoStroke Institute
Sounds exciting
crochet & croquet
