Standard KR1S cylinder port map?
maccas
Post by maccas »
Hi guys,
I was just wondering if anyone has a port map from a bog standard KR1S cylinder that they could kindly put up?
I've seen the KR1 cylinder port map in the magazine article with the TZR 2ma and RGV but would really like to see a KR1S portmap.
I don't have any standard cylinders otherwise I would do one myself and put it up.
mj43
Post by mj43 »
I have a brand new cylinder at home. I will make a map this weekend.
maccas
Post by maccas »
Mj,
Thats brill! Thanks alot!
It will be good to have a definitive measure on how far away I am from a stock cylinder.
Thanks again,
Be great to see the S port map.
I thought the difference in ports was limited to the fact that the
later KR-1S doesnt have the lower boost port opposite the exhaust (so 8 ports in bore instead of 9) :?:
mj43
Post by mj43 »
Piccy for the moment. I might have to do this again but it is a pain as the barrel is covered in its original protective grease. Measurements to follow
maccas
Post by maccas »
Cheers for that MJ!
The kips ports on the 1S barrel are considerably bigger than on a 1 barrel aren't they.
mj43
Post by mj43 »
Yep and 1R are bigger still....
