Posts: 877 Joined: Mon Sep 07, 2009 8:33 pm
Post
by maccas » Thu May 10, 2012 10:31 am
Hi guys,
I was just wondering if anyone has a port map from a bog standard KR1S cylinder that they could kindly put up?
I've seen the KR1 cylinder port map in the magazine article with the TZR 2ma and RGV but would really like to see a KR1S portmap.
I don't have any standard cylinders otherwise I would do one myself and put it up.
Dan
mj43
Posts: 1329 Joined: Tue Jul 25, 2006 7:44 pm
Post
by mj43 » Thu May 10, 2012 12:36 pm
Dan
I have a brand new cylinder at home. I will make a map this weekend.
Post
by maccas » Thu May 10, 2012 1:53 pm
Mj,
Thats brill! Thanks alot!
It will be good to have a definitive measure on how far away I am from a stock cylinder.
Thanks again,
Dan
Posts: 1966 Joined: Mon Oct 31, 2011 11:09 pm
Post
by Top-shaggy » Thu May 10, 2012 6:43 pm
Be great to see the S port map.
I thought the difference in ports was limited to the fact that the
later KR-1S doesnt have the lower boost port opposite the exhaust (so 8 ports in bore instead of 9)
mj43
Post
by mj43 » Sun May 13, 2012 8:50 am
Piccy for the moment. I might have to do this again but it is a pain as the barrel is covered in its original protective grease. Measurements to follow
Post
by maccas » Mon May 14, 2012 3:43 pm
Cheers for that MJ!
The kips ports on the 1S barrel are considerably bigger than on a 1 barrel aren't they.
Dan
mj43
Post
by mj43 » Mon May 14, 2012 5:22 pm
Yep and 1R are bigger still....
