Thanks Dan,
Guess what I will be doing tonight.
500bernie wrote:The number of hours that went into getting that finish (especially on the head and barrels) well my excuse is "I caught the ocd off the missus".
I saw the finish on Headcoats billet head and thought I want mine shinier!
I had no idea how hard it would be, but I am glad I did it
Thanks for the comments :)
When Martin was working on my engine, he could only see with one eye following an injury somewhat compared to looking at an eclipse of the sun through a telescope.
Some say he woke in the night and using a head torch walked into the kitchen only to see Bernie's engine "............the rest is history
Binetta Steve wrote: Some say he woke in the night and using a head torch walked into the kitchen only to see Bernie's engine "............the rest is history
R Whites Lemonadeeeeee ... I'm a secret Lemonade drinker.... #-o :lol:
Just finished the Southern Comfort :)
I was going to put all my NOS engine casings on and the NOS bottom exhaust bracket on, but I think it can wait until tomorrow :)
Hi Guys
Are these the correct exhaust gaskets, they look really small :shock:
... theyre muffler/silencer gaskets for the tail pipe
you need 11009-1922 for cylinders
... bet that carpet could tell a few tales
Thanks Danny I thought I was going bonkers #-o #-o #-o
The carpet hasn't seen that much action, as most of my time is spent in Premier Inns, I will dig out some more "action" photos :lol:
I like shiny but I think you are making a bit of a rod for your own back there Bernie
I would have lacquered the engine - as once it's together, in the frame and in use (i assume you are going to at least start it ) I don't think you will manage to keep the look
I know lacquer dulls the finish slightly but it does make for easier cleaning
Anyway it's your bike so good luck 8)
500bernie wrote:I don't have another one, but I may try to make one :)
Bernie,
I have a couple spare if you want one with no spring but you can use the one you have,
Nice ring by the way :wink:
Hi Gary,
So long as you keep the salt at bay, the polished alloy is reasonably easy to keep clean.
I always give the less accessible surfaces a coat of silicon or canuba wax, so it is a rinse and wipe.
I had fully polished engines on my S3 and H1 and they were quite low maintenance.
I tried laquer a few times but it does not bond well to the polished surface, and the first stone chip lets the water underneath and makes a mess of it.
Only time will tell, but if it is raining the bike will be staying in the garage :oops:
Bernie,
Thanks, I will have a go and give you a shout if I get stuck (if I bust mine) :(
You are the only person to have ever said "I had a nice ring" :oops:
I am going to have a go at shimming the bottom fixing now.
Post by jarno »
can't wait to se her finished bernie.
=D> =D>
jarno wrote:can't wait to se her finished bernie.
=D> =D>
Me to Jarno, it has taken a lot longer than I planned, I only intended to give her a quick tidy up, but she was in worse condition than I thought :(
But nearly done now and I am pleased with the results so far :)
Post by jarno »
=D> =D>
I know bernie if i want to change the the front tyre i end up with a complete new paintjob :roll: i always find something to improve on my bikes. :?
Quite a lot of the dirty work was done while I was working away from home...
Which ended up as...
