headcoats wrote:http://www.cycleworld.com/2014/12/18/20 ... SOC&dom=fb
Looks like a new model is coming out
So to date as of May 2016
Replacement front forks (old ones were shagged)
Thruxton fork internals which basically give the forks some pre load adjustment
Thruxton front wheel (old one was 19 inch,Thruxton is 18 inch and alloy)
LSL Clubman bars
Alloy single clock mount
Fork Gaitors
Chunky lockable fuel cap
Mirror hole blanks
Rear mudguard eliminator with Lucas style rear light
Thruxton front mudguard (will need modding to fit)
h***a 3 piston front caliper to replace standard 2 piston caliper (Bolts straight in [-o< )
Thruxton seat
Thruxton seat cowl
Angel eye headlamp to fit inside standard shell (looks more retro !!)
Stainless Predator silencers
Alloy bullet style indicators and rear locator brackets
Thruxton rear shocks (Longer) (Now TEC Shocks)
Removed air injection system
New horn
Skid plate
EBC Front Floating Disc (Old disc worn out and pretty heavy)
TEC Rear Shocks ( Cheap but a great improvement)
Plastic Side Panels (To Replace Heavier Metal Ones)
Well it's Green and a bike !!!
Anyone tackled the valve shims on a 4 banger
I know we have other bikes
Cams have to come out on the Bonny to change the shims but are on gears so the cam chain can stay in place
Still fecking daunting though
- Binetta Steve
I've done plenty mate (I'm a qualified bike mechanic, got certificates and note from my Mum and everything) but never actually tackled them on a Bonny but from screw and locknut to shim on/under bucket, it's just a job that needs planning and patience. If you want any advice let me know.headcoats wrote:Anyone tackled the valve shims on a 4 banger![]()
I know we have other bikes![]()
Well got the manual and watched the youtube videos , all 3 !! and I feel I can do the spannering but will have to get a mate in to do the maths of the shims
I understand now they tighten up with wear which isn't good
Specs for the inlet is 0.15mm to 0.20mm gap
Specs for the exhaust is 0.25mm to 0.30mm
Now it says you look for the medium of the above specs when calculating the new shim size
Is that correct
Bike has done 22K and I believe they have never been done
(I'm the third owner 21K when I bought it ) and I guess I have been putting it off but now is the time
Now first thing first will be measuring the gaps.......
Appreciate any help
Is that correct
Appreciate any help
I always calculate to the medium of the tolerance, I'd go for .18 and .26 when doing the maths.
In honesty they might be worn but still in tolerance, I've just done the NC30 and only 4 out of the 16 needed any adjustment and the motor is on 36000 miles so you never know with any luck you might just get to check them all and put the covers back on
Wow that is a result then on 36000 miles
The Bonny according to the manual should have had them checked at 12K so I'm coming up to double that
Yeah the VFR and CBR 4's need checking at 16000 but rarely need much adjustment, they have such small valves I don't think they wear into the seats or suffer from stretch at all unless they're being raced. The Bonny on the other hand, I guess you'll be finding out soon
Well the results are in and
Remember the spec for this engine was
Exhausts 0.25mm to 0.30mm
Inlets 0.15mm to 0.20mm
Well ALL inlets were 0.20mm I couldn't get a 0.21mm in, so right on the loose end of the spec but still in tolerance.
Exhausts were a mixed bag with right side 0.28mm and inner right 0.31mm
Left side BOTH were 0.25mm I couldn't get a 0.26mm in, so right side loose and left side tight
So looks like OK for now but we are on the loose and tight end of things
How many more miles do you think I should recheck ?
Maybe ride the summer and check again ?
- Binetta Steve
Let me think 22k and settings are bang on, I would take a punt on another 10,000 or 5 years based on your miles per year. Dont worry about it just rag it.
no rechecking, put them correct now, meaning 0.17/0.18 in and 0.27/0.28 outheadcoats wrote:
- Binetta Steve
Does this mean when you fit the barrels you can go out and give it some b...s
Yeah I guess they were ready "run in "
Not sure though as they didn't mark the pistons left and right when the breakers stripped it, so not sure what I do here ?
Maybe need someone to measure pistons and bore
or is 500 miles OK to mix and match
, just take it easy for a few hundred miles
Head is going to 2 stroke Guru Bob Farnham for a skim and gas flow
On the previous thread about shimming, he said that if I send the cams in the head he will shim it on the bench
Is this way just as accurate then ?
