As the KR power valve is effectively a switch what is the point of testing in between open or closed?TwoStroke Institute wrote:...The fully open and full closed runs is not the way to do it either....
anyone got an Ignitech race ignition?
TwoStroke Institute
TwoStroke Institute
No requires split timing between the cylinders, parallel, V or inline tandem timing still gets split. Split I mean that cylinders run different ignition curves.
MJ I don't know how to make it any simpler, than doing a full open then a full closed runs and comparing the 2, is not the best way to arrive at the correct effective open/close point (depending on your terminology).
crochet & croquet
TwoStroke Institute
TwoStroke Institute
