Electrical Problem?
neil68
Electrical Problem?
Post by neil68 »
Hi,Had a post on a couple days ago about bike not starting,a few replies telling me to check the stator.This was putting out about 17-18 volt at 4000rpm when checked.I have had to use my bike for work recently and today on the way home the rev counter gave up and have also noticed powervalves not operating either,even when turning the ignition on/off.Could this all be related to the stator problem?.Just to let you know all other electrics working fine horn,lights,indicators etc...
Dont know about stator,but mine blu rev counter,cdi,servo motor and rear light and brake bulb,and it was the regulator(i think).
Just put a brand new regulator on mine,as its blown 2 rear lights,just incase-better safe than sorry.
KR1 Man
Post by KR1 Man »
KR1 Man calling, I'm not much cop with generator defects relating to the kips/tacho although there is a series of tests in the manual, sect 15, 12-21. Just to say if it's stator, flywheel or reg-rec have spares of each if needed. Have you any useable engine spares? Please refer to my 'budget engine' posting for full details. Prefer to swap bits (but no problem if not an option) Good luck & best regards, KR1 Man.
when 17-18V is brought into your electr(on)ics, your asking for trouble. I wouldn't use it for 1m, I wouldn't even rev the bike any more. I'm even surprised your CDI isn't blown yet.
stop using your bike and fix the problem first, before everything is blown :idea:
If its blowing the rev counter and other bits then its the regulator thats gone.
Post by Bertie_Mollie »
Hi Neil,
Does sound like classic regulator / rectifier failure as the others have said. If you need a rev counter or CDI I can probably help.
Andrew
GWB KR1s C2 - Now gone :-(
GWB KR1 - YES IT'S DONE!
ZXR400L PROJECT :shock:
AND NO S****Y H****A'S
Usque Ad Mortem Bibendum
neil68
Post by neil68 »
Hi,
Have replaced rectifier and cdi,everything working again :D .One thing i did notice though was the powervalve (where the cables hook on) at the motor looked to have moved out of its operating movement,took off one of the cables and it re alinged itself properly.I thought the motor was gone,but it looks like it had "jammend" the powervalves half open half shut.All working fine again.
