It took a while to find one!
Hi from a newbee. I've been reading the posts and picking up some good tips. Many thanks to all.
Looks nice and welcome.
If your going to cadwell. Get some cheap plastics as good fairings are like rocking horse sh*t.
- SHimmer45
looks great.
+1 on the replacement fairing.
i wouldnt lean it off too much dont want to going pop!!
i used to run the oil pump slighly higher than required for peice of mind when giving it berries, used to have to change the plugs a bit more
nice cans what make are they??
- SHimmer45
Thanks for the advice, the end cans are from ebay. They were $82 Aus, so I saved £100 on tyga or others advertised. The quality is good and they bolted straight on. The link is below:
http://stores.ebay.co.uk/TARGET-SUPER-STORE
Thanks, yes well pleased. I didn't realise the ones I'd seen would be so variable. There doesn't seem to be any uniform value. Just what someone is willing to pay.
I know it sounds corny but it's great to be able to share views and valuable info on a forum like this. I've been rebuilding two strokes for thirty years (Vespa's- yes I know, even raced scooters for a few seasons) but fickle twin rice burners takes it to a different level.
you shouldnt have much bother if you keep everything right, I would also put the oil pump up slightly or just run PreMix. Definitely dont jet down.zebsp wrote:fickle twin rice burners
Keep the fuel tank fairly full at the track, avoid starvation. Maybe have a spare chain if the current one is old.
Have fun
